i seem to always break the bead on one of my tires because of riding it too hard or not having enough pressure, etc. i read on here that 3 psi gives enough cushion, but that seems low to me, so i had between 5-7. do i need to add even more?
how much air pressure in rawhide 3's on a max ii?
I'd run them at around 2-3 psi for a soft ride and good traction, but if doing that I would suggest buying "K lock" bead lock rims from Recreatives.......it is very difficult to pop a bead on these rims, even at only 1psi. Amphibious Six-Wheel Drive All-Terrain Vehicles: MaxATVs - Call 1-800-255-2511"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Matt O. Has his own Beadlocks as well. I have not gotten any myself yet, but other members have talked about using them at 0psi and not breaking any beads. Thats a good beadlock!
Attex Super Chief - Sold.
+1Originally posted by Mike View PostNo, like sixbysix said you want lower PSI for increased traction and the added benefit of a softer ride.
Believe it or not, even the difference between 1 and 1.5 psi makes a noticable difference. Most of my pals are running between .5 and 1.5 psi with the new RI rims and not popping beads at all...Tim
98 Max II
try swapping it with another (like the mid-rear) to eliminate that theory, maybe it's a problem with the rim and/or tire on that one.Originally posted by andylmusic76 View Postthat's what i thought, but why do you think the rear passenger tire always comes off the rim? the others don't...maybe i hit it just right??
Tim
98 Max II
maybe its just a loose nut behind the sticks.....Originally posted by andylmusic76 View Postthat's what i thought, but why do you think the rear passenger tire always comes off the rim? the others don't...maybe i hit it just right??
thats what they always tell me
but seriously with the newer style rims i run around 1.5 lbs and i can do dognuts on the pavement and they all stay on!!!!
they dont call me mad because im angry!!!!! im just a little crazy thats all!!!!
mental note: use spell check after drinking 2 or more beers!!!!!
ill forgive you big bird
but you have it comming to you at the instalation dinner!!!! hope to see you there !!!!
whipper i never claimed to a good speller , actualy ive never claimed to be good at anything except drinking beer !
Come on Whipper,dognuts are the same as donuts but they have way less calories and some say are less fattening
