That is not the new Avenger tire we just tested the first ones out of the plant I purchased them yesterday and we tested them today check youtube under AAA argo
New Argo Avenger tires?
I posted 4 videos on youtube to view the first set of new Avenger tires in test they performed exceptionaly well with confirmed GPS speeds 5.4 kms in high gear and 5.0 kms in low with the 3rd. tire reversed we got top speed of 5.0 forward and 2.4 in reverse we tried all configarations this was the best overall result with all tires facing forward there was no reverse speed to record the GPS actually said 0.0
New Avenger Tire vs. Frontier Tire
Philip, the Frontier tire only measures 23 to 23.5" @ 2.5 to 3 psi. they call it a 24" tire. By 10" wide. It is a 4 ply tire.
The new "Avenger" tire measures 24" @ 3.5 psi. By 12" wide. they call it a 25" tire. It is a 4 ply tire.
The tread depth is the same on both tires.
It's well known that you usually only achieve the stated tire diameter at the maximum rated tire pressure which is usually 7 psi.
Your test results for these new tires should blow away ANY need to buy that China unit, Argo knock-off!!!! Continue supporting North America's workers & OUR economy!! Who needs built-in propulsion, at the cost of jobs?!? These tires will help us older unit owners as well! I'll budget a set for my Conquest, even if it's one tire per month!! I've got fair tread depth for one more year on my rawhides & then, keep em around for winter track use.
Last edited by lewis; 03-14-2009, 03:55 AM.Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
Stats On New Avenger Tire
Ok, here are the stats on our tests related to AAA Argo video. All results are verified by GPS.
Argo Avenger 700 (not EFI)
One person 280 lbs.
Full Tank of Gas
Estimated 3-5 mph wind
Temp -3 degrees C
Some Ice on Pond
5 psi in tires
WATER TESTS
Best Run with Rawhide III's.....2.9 k/hr or 1.8 mph.
Best Run with New Avenger Tire......5.4 k/hr or 3.4 mph
Reverse Speed with New Avenger Tire....0 k/hr or 0 mph
Directional Control with NAT (New Avenger Tire) Excellent (steers like an ATV on land)
We then tried to rotate 2 tires backwards (one axle) to get some reverse.
Front Axle:
Best Run 4.4 k/hr or 2.7 mph (loss 1 k/hr or .62 mph
2nd Axle:
Best Run 4.9 k/hr or 3.0 mph ( loss .5 k/hr or .31 mph)
3rd Axle:
Best Run 5.0 k/hr or 3.1 mph (loss .4 k/hr or .24 mph)
Rear Axle:
Best Run 4.0 k/hr or 2.5 mph (loss 1.4 k/hr or .87 mph)
Best Position for reversed tires: 3rd axle from front
This will give you 5.0 k/hr or 3.1 mph in forward, and 2.4 k/hr or 1.5 mph in reverse.
General Observations:
1. Hardly any difference in speed whether using Low or High Gear
2. Tires are so efficient in water that they really eat up the HP.
3. I feel we could have achieved faster water speed with more HP. or improvements to the drive train to increase tire RPM.
4. It looks like this tread design does not require that 50% of more of the tire to be above water line to achieve speed.
I will be posting some stills and more video of this testing in a couple of days. Sorry about all the detail, but for those who are interested these are the verified statistics.
The same speed in hi or low doesn't surprise me. I've seen Al swim in his frontier at a low rpm (rare
) and it moved very well. So you can basically run the engine at half the speed, and still outrun a set of rawhide III's. Interesting idea about running one tire reversed.. runamuks never did like to propel backwards.
Lewis, I noticed a rawhideIII on the left rear of the avenger. Do you know if that was the only one on the machine.Last edited by Roger S; 03-14-2009, 12:37 PM.To Invent, you need a good imagination and a pile of junk. (Thomas Edison)
Originally posted by Roger S View PostThe same speed in hi or low doesn't surprise me. I've seen Al swim in his frontier at a low rpm (rare
Roger,
This was a primary run and only 7 tires and wheels came in that day. The other was in transit. The noticeable difference was that on a straight run the vehicle led to that side. Our testing was done with all new tires in place and all speeds were documented with a GPS and with different load factors as well as reverse and tire swaps. We also tested with tracks for several days of use.
lewisLife should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
