New Argo Avenger tires?
  • #31
    That is not the new Avenger tire we just tested the first ones out of the plant I purchased them yesterday and we tested them today check youtube under AAA argo
    • #32
      tires
      they look like updated, ancient jiger tires.....
      • #33
        I posted 4 videos on youtube to view the first set of new Avenger tires in test they performed exceptionaly well with confirmed GPS speeds 5.4 kms in high gear and 5.0 kms in low with the 3rd. tire reversed we got top speed of 5.0 forward and 2.4 in reverse we tried all configarations this was the best overall result with all tires facing forward there was no reverse speed to record the GPS actually said 0.0
        • #34
          New Avenger Tire vs. Frontier Tire
          Philip, the Frontier tire only measures 23 to 23.5" @ 2.5 to 3 psi. they call it a 24" tire. By 10" wide. It is a 4 ply tire.
          The new "Avenger" tire measures 24" @ 3.5 psi. By 12" wide. they call it a 25" tire. It is a 4 ply tire.
          The tread depth is the same on both tires.
          It's well known that you usually only achieve the stated tire diameter at the maximum rated tire pressure which is usually 7 psi.
          • #35
            link to firstallin's video above. fast forward to 6 minute mark. think it's widescreen footage that youtube displays in 4x3, so things look a little tall and narrow.
            • #36
              We need more pictures or videos of these tires!
              • #37
                Your test results for these new tires should blow away ANY need to buy that China unit, Argo knock-off!!!! Continue supporting North America's workers & OUR economy!! Who needs built-in propulsion, at the cost of jobs?!? These tires will help us older unit owners as well! I'll budget a set for my Conquest, even if it's one tire per month!! I've got fair tread depth for one more year on my rawhides & then, keep em around for winter track use.
                • #38
                  New tire for Argo
                  Ken asked if i would post this video of the new tires so here they are in action. Hope you guys enjoy. They work great!
                  3.5 mph measured with gps. Trials with one person=3.5 Speed was slower with 3 people but still very impressive, speed was recorded on the ride.
                  • #39
                    Pictures of the New Avenger tire North American Version
                    Here they are beside the Rawhide III as Tested by myself Check AAA argo on youtube.
                    • #40
                      Stats On New Avenger Tire
                      Ok, here are the stats on our tests related to AAA Argo video. All results are verified by GPS.
                      Argo Avenger 700 (not EFI)
                      One person 280 lbs.
                      Full Tank of Gas
                      Estimated 3-5 mph wind
                      Temp -3 degrees C
                      Some Ice on Pond
                      5 psi in tires
                      WATER TESTS
                      Best Run with Rawhide III's.....2.9 k/hr or 1.8 mph.
                      Best Run with New Avenger Tire......5.4 k/hr or 3.4 mph
                      Reverse Speed with New Avenger Tire....0 k/hr or 0 mph
                      Directional Control with NAT (New Avenger Tire) Excellent (steers like an ATV on land)
                      We then tried to rotate 2 tires backwards (one axle) to get some reverse.
                      Front Axle:
                      Best Run 4.4 k/hr or 2.7 mph (loss 1 k/hr or .62 mph
                      2nd Axle:
                      Best Run 4.9 k/hr or 3.0 mph ( loss .5 k/hr or .31 mph)
                      3rd Axle:
                      Best Run 5.0 k/hr or 3.1 mph (loss .4 k/hr or .24 mph)
                      Rear Axle:
                      Best Run 4.0 k/hr or 2.5 mph (loss 1.4 k/hr or .87 mph)
                      Best Position for reversed tires: 3rd axle from front
                      This will give you 5.0 k/hr or 3.1 mph in forward, and 2.4 k/hr or 1.5 mph in reverse.
                      General Observations:
                      1. Hardly any difference in speed whether using Low or High Gear
                      2. Tires are so efficient in water that they really eat up the HP.
                      3. I feel we could have achieved faster water speed with more HP. or improvements to the drive train to increase tire RPM.
                      4. It looks like this tread design does not require that 50% of more of the tire to be above water line to achieve speed.
                      I will be posting some stills and more video of this testing in a couple of days. Sorry about all the detail, but for those who are interested these are the verified statistics.
                      • #41
                        The same speed in hi or low doesn't surprise me. I've seen Al swim in his frontier at a low rpm (rare) and it moved very well. So you can basically run the engine at half the speed, and still outrun a set of rawhide III's. Interesting idea about running one tire reversed.. runamuks never did like to propel backwards.
                        Lewis, I noticed a rawhideIII on the left rear of the avenger. Do you know if that was the only one on the machine.
                        • #42
                          Bw6,
                          Exellent write up of the new 25 inch Frontier tire.
                          • #43
                            BW6, that's awesome info, TKS for posting it
                            • #44
                              Roger,
                              This was a primary run and only 7 tires and wheels came in that day. The other was in transit. The noticeable difference was that on a straight run the vehicle led to that side. Our testing was done with all new tires in place and all speeds were documented with a GPS and with different load factors as well as reverse and tire swaps. We also tested with tracks for several days of use.
                              lewis
                              • #45
                                Avenger tires?
                                Does anyone know what these new tire weight.If the goodyear tires are being discontinued what will R.I. do for tires?
