New Argo Avenger tires?
  • #16
    Another tire that I would love to have but could never afford,too bad. I don't know what the exchange rate is now but $1080 + tax for 6 tires,plus shipping???CRAZY
    Don't get me wrong,if I could I'd buy a stack of them. Kinda look like the old,wide fatcats. If the 24" frontiers fit a MAX 2 and these are a true 24" imagine these on a max 2.
    • #17
      Wow, talk about a runamuk on steroids.
      Bw6, please don't measure them at 2.5 psi and tell me they are 23.75" or less.
      That gives me something to look forward to some day. A used 8 wheel frontier, 23hp upped to about 40, and some of these tires.
      • #18
        Oh man! I got to ride more and wear dowm my Frontier's tires so I can replace them with those!!
        • #19
          Well I know what's going on my Max IV with Matt O's rims. Once I wear out the 25 rawhides that is.
          Mike
          • #20
            It'd float so high, the tub would be out of the water.
            • #21
              Bw6 ,
              The new 25 inch Frontier tire " looks " like the tire lugs across the tire are even taller than on the 24 inch Frontier tires? Is this correct?
              • #22
                Tire Lugs
                Mudbug3, I measured them against a standard Frontier tire and they are exactly the same, even the lug pitch seems identical. I guess they didn't want to mess with success Tire design R&D can get very expensive, as Argo found out with their "new" diagonal tread pattern, that doesn't swim.
                The picture really doesn't do these tires justice. But kudos to ODG for advancing our sport, even though it is self-serving.
                • #23
                  New Argo Rplacement tire
                  Good Morning Gentlemen,
                  The new tire is more than outstanding. I have had the privilidge of testing the tires on an avenger for some time. The tire more than doubles the water speed in the water as well as works great in mud and snow. Another thing I have notices is that they run outstanding with rubber tracks with very little chain windup. The tire also has a very flat face and gives the appearance of a box design tire. gives a very good footprint.Great tire on its way for all of us.
                  Regards
                  Ken
                  • #24
                    new tires
                    If those tires will fit on a MAXII will a 23 horse Kohler, the MaxII would be transformed into the biggest baddest machine of the planet. I can see tire swaps and hoped up MaxII's absolutley dominating in swim speed, climbing, mud, ground clearance, balance and over all abilities. I can see an AATV revelotion now with quad owers duming their four wheelers for old MaxII's. That tire is gonna change everything!
                    • #25
                      Give Tory a set of tires, and a blow torch, he'll fit them on a maxII
                      It might not be that far fetched.. he stuck those goodyear ATT 25x11x9's? and Matt's wheels on a II he has. Bolting them on might be the "easy" part. Prolly need wheel spacers or longer axles. Regear the machine, put some JerseyBigfoot Blackbird style mud flaps on the sides. It might not be as tippy as with frontier tires.. the 9" wheels would stick out an inch farther. I think a guy like our web master should do it. Put that 30 hp twin to work.
                      • #26
                        tires
                        Ya I think it would work. Put a 1 1/2 wheel extension on the axles to get the tires away from the tub. I don't think it would have to be regeared just a bigger motor and a red spring clutch should do the trick!!! I'll bet a MaxII could get six MPH in the water.
                        • #27
                          Hey guys, so there isn't any difference in the new Argo tire and the old 24" version, besides the use of a 9" rim?
                          I don't think I'd agree that a Max II with these tires would be the ultimate AATV, but hey maybe we could eventually get a bunch of folks with some built up, highly capable AATV's together with different tire combos like some of the Hustlers out there like Don, Boncrshr, Meinfeld, Mudbug, and my Hustler on big Super Swamper Vampires and some Max II's and IV's and some Argos like that one on Mud Bug tires and see which vehicle/tire combo would work best in the deepest, nastiest mud holes that even the largest lifted 4 wheelers would only dream of treading.
                          • #28
                            new Argo Avenger tires
                            [QUOTE=Bw6;35468]Mudbug3, I measured them against a standard Frontier tire and they are exactly the same, even the lug pitch seems identical. I guess they didn't want to mess with success Tire design R&D can get very expensive, as Argo found out with their "new" diagonal tread pattern, that doesn't swim.
                            bw6- I understand thay you are saying that the tread pattern is identical But are you saying that the overall outside diamater of the two tires are identical???
                            • #29
                              But the Avenger tire is 12" wide instead of the 10" of the Frontier.
                              • #30
                                frontier tire 23-23.5+" dia @ 2.5 psi depending on who you ask. 2 ply? 10" wide.
                                new big brother tire. Bw6 says 24" dia @ 3.5 psi. 4 ply. 12" wide.
                                tread lug and spacing looks the same
