I read .through a lot of the threads on tires and have some questions and ideas that i did not see addressed as well as my own experience with a few ATV tires. I am hoping to get an AATV in the next week or two so hopefully I will get to test these ideas out...
Questions:
1. I did not see any threads of folks using more than one tire model at the same time such as mudders on 4 rims and swimmers on 2 for example. anyone using a setup like this? what are you experiences?
2. I am wondering how they perform with different ply and sidewall strengths. for example on my ATV I removed the Mud Lites and installed these Sedona Mud Rebels . The latter tires has a much more rigid sidewall and even runs flat with compressing on my ATV.... Is a stiffer sidewall better or worse for AATV use
3. Anyone tried a sand (paddle) tire for swimming?
4. I am also wondering how much space needs to be between each row of treads to swim well? from what I have read it seems that tread that is too close to the one in front does not swim well regardless of the style of tread.
5. Several folks said the Mud Bug and Vampires swim well. however they do not have a "V" that is joined to make a scoop so what about how vertical the side of the tread is as opposed to some that dont swim well seem to be more sloped on the leading edge of each tread lug...
Ideas:
1. I don't see anyone actually modding a tire for better swimming traction. If my thinking is correct, the reason the tires swim in the reverse setup is that they act as a scoop to create a "paddle" boat effect. Thus the center of the V is closed so water cannot slip through the scoop.
My thoughts here would be to use a tire regroover to modify a mud tire so it swims better in the action direction and less resistance in the reaction direction... I would do this by finding a tire where the tread can be made to create multiple mini paddles and then put like a 45 degree bevel on the trailing side of the tread to cut down the "re"action force. (though I think it depends on how deep your tires sit when swimming. if fully submerged it should be a benefit) Also notch tires to get tread that is parallel to the width of the tire creating a better "paddle". I am browsing though various tire pics now but the Mud Rebels I referenced above have a tread design that seems to lend itself to this mod...
Questions:
Ideas:
