I was needing to paint the wheels for my racer and didn't want to go to the trouble of dismounting the tires. i was going to break one bead then mask the tire with tape and newspaper, but found an easier way to do it. with the bead broken, i stretched the neck hole of a T-shirt over the rim, then turning the shirt inside out as i worked, stretched the body of the shirt over the tire. stuff any excess down between the wheel and tire and paint away. this worked well on 8" rims, for 12's you might have to cut the neck hole out a bit bigger. the shirt i used was an XL, but i might go buy a few 4XL's just to keep around for this task. (for some reason pictures loaded out of order, but you can get the idea
