stonewall
What I am saying is that you don't have sufficent lower tub clearance to be able to run even a 1" inch grouser over a 25 inch tire. You would probably have to go down to a 20 inch tire with a 1 "inch grouser. The shorter side walls of a smaller tire don,t give you the boyancy that you have with a 25 inch tire. When you have a smaller less boyant tire, plus the additonal weight of each UHMW track section, thats on either side of the tub, the whole tub sits lower in the water. This then makes the tracks and the smaller tire also sit lower in the water. If a track section is more than half way under the water, then your water speed drops off -----> BIG TIME !
You now have a great mud machine with hardly any water speed.
