Has anyone every tried them? How do they swim? Should I put them on forward or backward for best swimming ability?
gbc gators 22"
I think if you put these tires on several machines it would be hit or miss for swimming. I have a set of 25" on my Max2 and they swim pretty good. They are nearly identical to MUDBUG tires with a slightly less tread height. I've tried them on my Argo and they are not impressive. I also tried them on my Super Swamp Fox and they swam well. It all relates to axle placement. The lower your axles are mounted in the body, the quicker you will swim with these tires.
Originally posted by Noel Woods View PostI think if you put these tires on several machines it would be hit or miss for swimming. I have a set of 25" on my Max2 and they swim pretty good. They are nearly identical to MUDBUG tires with a slightly less tread height. I've tried them on my Argo and they are not impressive. I also tried them on my Super Swamp Fox and they swam well. It all relates to axle placement. The lower your axles are mounted in the body, the quicker you will swim with these tires.
I used a heat gun and got a bit more clearance on the lower tub. Figure 2-3 hours work to do that. There's plenty of clearance now and they don't rub. The machine is very capable with the increased ground clearance. If you compare a vehicle with tires to another one with tires, this little Max2 has always come out on top.
IMG_0713.jpgIMG_0691.jpgMaxII axles are 25" center to center, so true 25" tires should touch each other. My winter project is a maxII with a lengthened frame to accept 25's easily. I know I can get at least 1/2" extra between axles, but I'm hoping for a full inch.....wouldn't 26"ers (with clearance)be cool? Add big HP and maybe even lower the gear ratio a tooth.
It's all Mikes fault. He got me hooked on the Idea. I'm going to reread his post about 25" tires on maxII http://www.6x6world.com/forums/max-a...es-max-ii.html
I'm sure I've forgotten important stuff.
Originally posted by thebuggyman1 View Post[ATTACH=CONFIG]7562[/ATTACH][ATTACH=CONFIG]7563[/ATTACH]MaxII axles are 25" center to center, so true 25" tires should touch each other. My winter project is a maxII with a lengthened frame to accept 25's easily. I know I can get at least 1/2" extra between axles, but I'm hoping for a full inch.....wouldn't 26"ers (with clearance)be cool? Add big HP and maybe even lower the gear ratio a tooth.
Oh Jim, I'm going to be excited to see this build!"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Well I for one, think you're a pansy! Get two of them and cut them in half, and make an eight wheeler out of it!
That way, you could spend an entire year contemplating your next move, waffle selling it completely, amass too much money in parts and criticize yourself when you misprioritize other projects in its place....
Give me a call; I'll coach you along.
I like the blue bodies a lot. Get a heat gun and some home made beer and have at it! Very cool project. Custom stuff's the awesomest...sigpic
