The biggest difference that I can see is 1) weight of track 2)traction .......without having all the specs, you give up some traction to save in weight. Which is more important, which cleat works for you...
The adairs are lighter. I personally don't know how much. My guess is probably half the weight. I can't imagine damaging the 4-ply belt either which is probably good. Looks like it would be a little bit more of a pain to field-repair that the "bolt-hole pattern' of the escargo. Weight isn't everything, but an 8x8 escargo track to fit over 25" tires weighs 186 lbs each (don't quote me on that, but I'm fairly certain) They can me made lighter with wider spacing on the crossers and/or the addition of UHMW-escargo-shaped crossers (each one is 1/2 the weight, this is using 1" thick UHMW). I read the other day that Adair uses even thicker (stronger) UHMW now. A single vertical steel cleat that is centered under just the tire-width (actually narrower) has tremendous "bite." Sounds like Adair has some good traction enhancers though too. Others know more about these than I. Right now I am .....considering.... putting together a hybrid escargo track to play around with only because I am addicted to screwing around. Somewhere in the middle is probably the answer for the best overall track, (maybe not?) Replacing 2/3rds of my steel crossers with UHMW only really saves 1/3rd in weight overall (still significant). There are benefits to all steel, there are benefits to all plastic. There is nothing that the escargo cannot do within reason. They do lower your top speed....I hope to have more reports on that front shortly.
In the name of helping others (isn't the internet great), how much does (will) a set of rubber-belted Adairs weigh for an 8x8 over 25" tires. How much does each UHMW crosser weigh? I think they look good!
