When I purchased my 400 Chief it had a worn shift lever on the left side, which I replaced with a new one. It worked fine at first, but within a few hours of use it started to pop out of forward gear on that side (left side). I pulled the shifter and the pin had worn already on the forward gear side. We just pulled the transmission and took that side apart. The teeth on the forward side of the shift collar are heavily worn, and the teeth on the carrier plate are also badly worn. You can easily see how it would the teeth would want to ride into neutral under load. I have a "new-ish" shift collar which I can put in, but given the wear on the carrier plate we suspect the issue could continue or at best quickly wear down the teeth my new shift collar. Since I don't have a replacement carrier plate, would it be possible to just flip it? The teeth on the other side of the carrier plate are not worn at all, but should they have a slight bevel on them to easy shifting? They are square edged. Other than that there seems to be no difference from one side of the plate to the other.
If it would be best to replace it, does anyone know the price? Can I get them from Recreative Industries, and will they work with an older transmission? Mine doesn't seem to have any thrust washers if that helps date it.
Thanks for any suggestions.
