My sons 1987 max11 has been sitting since 05 now he thinks he wonts it going again any idea about ball park cost to go through trany?? So he knows he has to open HIS check book
t20 rebuld $
Transmission Crafters is currently relining T-20 bands for $35/each. Here's ARP35's invoice, and my invoice was the same for a set I had done last fall.
Like Toys4Me says, a lot of the O-rings and seals are generic pieces that can be found almost anywhere including RI, Motion, local hardware store, McMaster-Carr, etc. If you need any of the internal hardware (bearings, drums, replacement bands, shift collars, plungers, etc.) they're only available new from RI or as used pieces from other members. RI has provided a seal kit in the past that includes all of the seals, the O-rings and the case-half gaskets, along with new thrust washers, snap rings, c-clips, fiber washers, etc. I've always found it easier to get the complete kit mainly because RI used to be very local, and could often get a good break on prices. If the machine has just been sitting for a while and the transmission didn't exhibit any problems in the past, you might be able to just get away with a fluid change and a double-check on the band adjustment.sigpic
If you open up a T-20 the case half gaskets should be purchased from RI. The gaskets give the clearance for the internal parts. Using just a sealer on the case and center support can leave no end play. I would order the gasket and seal kit from RI or a dealer.
