Hello,
Over the winter I took apart my t-20 to replace a broken band and had all other bands relined. Redid all seals and bearings and also pinned the u-channels on the front of the transimission. Everything seems to work fine. Only thing I notice is that the bands seem to require more operator pressure on the laterals to get the same results as before. In order to say pull a heavy load I need to push way harder to get the bands to stop slipping then I used to and its way harder then my other machine. I used the correct atf type F fluid. little less than a quart and about 4 oz of friction modifier. Anyone have any ideas for me? Maybe needs bands tightened more? Less friction modifier?
Thanks Daniel
Thanks Daniel
