What can I use for the band adjustment tools since I don't have a set what thickness are they and what can I use I took apart my trans and you can see the grease marks on the bolts but I'm reusing my bands I need some help with this one
t20 tools
The tools are .187 " thick. You want .312 total movement on a plunger. If you get it close and reinstall it in the chassis setting the total movement of the sticks is the best way to go. A max II should have 5.5 to 6 inches of total movement measured at top of sticks. Max IV needs 7" because the sticks are longer. Movement at transmission is the same. Hope this helps.
