hagen trans trouble
  • hagen trans trouble
    Where would I obtain a kit to rebuild my control cylinders for my hagen trans.
    There are just orings in the cylinders and caps. I got mine from McMaster Carr.
    Keith.
      Take one apart and take lots of pictures as u do...then you have a pattern to go by.
      locate o rings at local farm supply or maybe tractor or hydraulic shop and replace them..lube with vaseline when installing rebuild and fill and bleed.
      JM2CW
      Al
      E D I T...
      Just something to consider; these machines have not been made in over 45 years, thus parts availability is pretty much non existent. There are NO parts for the Hagen, the controls are sealed with O rings, clutches can be upgraded as with engines, drive belts but the end result is there are limits to what you can get in regards to parts for these old machines...
      MUSCATEER 6x6
      MUSCA TUR BOTA then eh?
      94 F350 4x4 7.3 IDI ZF 5sp
      Al "Camo pants"
