I finally was able to get my Max ll out for a test drive. The first test and It turns to the right but no left turn. Reverse is not working. The tranny has new fluid and this is the first test since being rescued from a farmers field. Do you think it needs a rebuild? Who do you suggest?
Max ll t20 transmission issues
Is the stick movement equal on both sticks or does the left stick move easly a lot. If so you may have a broken band on left side. You have to hold back hard on sticks for reverse. It should work on the side that steers if reverse teeth,shift collar and shift pin are intact. Where are you located?
The t20 isn't that bad to repair and lots of advice here. Before you tear it apart measure the total forward and full back movement of both sticks and let us know what it is. I think it needs to come apart but would like a bit more info first.
It sounds like the bands are in place. Next thing to do is remove the diamond shaped shift levers from the top of the transmission and inspect the pins and shift collars. Yours probably has a bolt on retainer that holds shifter in place. If it's a real old one it will have a snapring under the diamond. You will need to look in the hole and roll transmission over to inspect the slot in the shift collar for breakage. The shift pins should be round not flattened. Keep us posted, it may be as easy as a shift pin replacement.
Originally posted by boyerbl View PostI have inspected the shift collars and pins and they are good. Now I am in the process of pulling the tranny so Maximum Off Road can rebuild it. He seems a lot less costly than the $300 + parts Richards Relics quoted me.
$300 plus parts!!! Holy crap that's expensive.l like to buy stuff and no I don't do payments!
Guess it would depend on what the 300.00 includes. If he is going to tear it completely down, hot tank the cases, make sure that everything is within spec including the bearings, bushings and wear surfaces and repair or replace as needed then that sounds like a bargain to me. Now if it just includes tearing it down, finding the malfunction and replacing parts, and put Orings in it and call it a rebuild like some do it not worth the money.
Exactly.Originally posted by Joe H View PostGuess it would depend on what the 300.00 includes. If he is going to tear it completely down, hot tank the cases, make sure that everything is within spec including the bearings, bushings and wear surfaces and repair or replace as needed then that sounds like a bargain to me. Now if it just includes tearing it down, finding the malfunction and replacing parts, and put Orings in it and call it a rebuild like some do it not worth the money.
No, not really. He has burned a lot of people with crappy parts. In my opinion, he is best avoided.Originally posted by hipowerone View PostRichardsRelic's seems to be a reputable source. If you question what is included for the price, I am sure that they will tell you.l like to buy stuff and no I don't do payments!
Reputable source? Definitely not. I could tell countless stories of people that I've come across that have been burned by him. Including the transmission that he supposedly "rebuilt" for someone that I helped fix the correct way. It looked like it was only opened up and then put back together.....no new parts installed or anything.Originally posted by hipowerone View PostRichardsRelic's seems to be a reputable source. If you question what is included for the price, I am sure that they will tell you.
Drew, you hit the nail right on the head! Buyer beware......avoid him as a source of parts. There are higher quality and lower priced options out there.Originally posted by amphibious drew View PostNo, not really. He has burned a lot of people with crappy parts. In my opinion, he is best avoided."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
I have decided to fix the tranny myself. I fixed the Briggs Vanguard motor that wouldn't shut down (a new kill wire attached to the magnetos). Question... should I attempt to just install the bands and plunger O rings or go for the complete rebuild? That is if it's just a broken band and the drum isn't scored. Who do you suggest is the best source for parts?
