My belt sticks out of my secondary clutch is there a spacer or something that could be missing in between the sheaves? I'll post a few pics when I figure out how to
Argo response clutch
Here
I'll be darned if that belt just doesn't look to be the wrong size 'dawg. What does the top width measure on it? I'm guessing over 1.25". I'm not around Argos that much but speaking generically, your clutch looks like it's spaced about properly, if not a bit on the wide side already. I don't know what top width your machine calls for, but I think 1-3/16" would fit in there a lot better.sigpic
It's definitely the right size belt. I just ordered a new one and the new one is a touch wider. Yes it shifts fine it's just our other machine the belt sits more flush so I figured maybe there was something missing it's a new machine to me.
I have about 1/4" with the new belt. If you say it's good I'll run with it I just didn't want to screw up a new belt.Attached Files
1/4" is too high. just below flush to 3/32" proud is normal, up to 1/8" proud is fine.Originally posted by jadawg27 View PostI have about 1/4" with the new belt. If you say it's good I'll run with it I just didn't want to screw up a new belt.
Wel there you go, that'll do it. I'd order both and use whatever was needed to set the belt just above flush.Originally posted by jadawg27 View Post[ATTACH=CONFIG]14921[/ATTACH]Ok so I pulled my clutch apart today looks like I'm missing 30 and or 30a shows 30 is .050" and 30a is .025 do I need both or just one?
