I just finished installing my rebuilt T-20 and after attaching the springs to the control levers. My movement seems to be between 4 to 5 inches. The manual says there should be between 6 and 10 inches of movement. What is the correct amount for a rebuilt T-20? How do I test it?
T-20 rebuilt stick adjustment amount of movement
as long as the T-20 is functioning correctly and the throw is the same on both sticks, there is no real "correct". it is just a matter of finding where it is comfortable for you. I run mine as tight as i canOriginally posted by egoperf View PostThat's fine. 6 to 10 is way too muchA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
I believe the recommended throw varies by model,make of machine. 6-10 is for a iv if I remember correctly, 4-5 is a II as I recall?sigpic
that would make sense as the length of the actual laterals would change the throwOriginally posted by ARGOJIM View PostI believe the recommended throw varies by model,make of machine. 6-10 is for a iv if I remember correctly, 4-5 is a II as I recall?A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The "U" channel trans is next to impossible to over tightened due to how it's adjusted.Originally posted by boyerbl View PostI just finished installing my rebuilt T-20 and after attaching the springs to the control levers. My movement seems to be between 4 to 5 inches. The manual says there should be between 6 and 10 inches of movement. What is the correct amount for a rebuilt T-20? How do I test it?Acta non verba
