After riding the diesel magnum around a bit, it has become apparent that it is in need of some clutch adjustments.
The background info:
The TEAM rapid response primary I bought off eBay was designed for a Club Car Carryall 1500 4x4 Diesel running a 20hp, 3600rpm Kubota diesel. I thought this was pretty close to my Thermoking (Yanmar) ~24hp at 3600rpm diesel. The original Magnum 18hp would have spun at 3600rpm as well. Should be good to go, on paper.
The secondary is just the original one that came on the machine (1988 8x8 I/C Magnum). Salsbury?? It is in decent shape, so I figured I'd just leave it, and if it became a problem I could deal with that later.
What's happening:
The primary is not engaging at a decent rpm. It engages near top rpm. My "seat of the pants" tach measures around 1800-2000rpm or higher. This is great for having decent power and torque to tour around in high gear and have enough nuts to rip right around, but it makes it hard to drive nicely. You can't just feather the throttle a little and have it engage. When it engages, it ENGAGES!!! Which is all fine if you just wanna grip it and rip it. The plan with this machine is to run it on our yearly camping trip. The hellish portage on the way in is not really a grip it and rip it kind of situation. Slow and easy is more the name of the game, as there's lots of rocks and trees. Watching this years rental rig (2018 Avenger 8x8) run over that path told me a lot about what I need to make my machine run like, and it's nothing like what it runs like now.
So, besides the engagement rpm, I also don't get full shift.....ever. Not even anywhere near. The belt goes maybe 3/4-1" into the secondary. This isn't as big of an issue for my situation, but it means that on a long flat straight, you're screaming along in high gear at a brisk walking speed.
My conclusions:
From my limited knowledge/experience with CVT's, I assume that I will need some heavier flyweights for the primary, and maybe see if I can lessen the spring tension on the secondary. The secondary may be a bit of a problem, as I am having difficulty getting it off the transmission input shaft. Can't imagine it's all that fun to adjust while it's mounted.
I'm also having difficulty finding any info on flyweights for the TEAM clutch. I can find stuff for Arctic Cat and Polaris sleds, but they run higher rpm and more power. Dunno how this will translate over to a diesel running lower rpm. Any help would be wonderful!
Thanks,
Rudy
What's happening:
My conclusions:
Thanks,
Rudy
