upon tearing my tranny apart I found that the clutch that was attached to the imput shaft to have play.heres my questions.it there supposed to be a bolt that retains the secondary on the input shaft. or is it a press fit? there is no bolt on mine, ive never sean a secondary clutch that didn't have a bolt maybe that explains the loosenes or wiggle on the input shaft.the bands seam to be in pretty good shape and all the gears have minimal wear.im gonna replace the bands while im there any gow.my biggest concern now it the clutch and shaft wick I have out on the bench in one piece ..ty all for the input
max t20
it may be broken off in the shaft. If so, you will need to remove the clutch from the shaft to get the broken part out. If you are referring to play as in the clutch can get closer/ farther from the sprocket, it is common. I've seen up to 1/4" on transmissions that were working just fineA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
guessing that if he has the clutch and shaft removed from the trans as a unit, they are stuck together with no playOriginally posted by msafi65 View PostMeasure the shaft for wear. If it measures under .872” anywhere the clutch sits the shaft needs to be replaced. Even setting new clutch with lock tite will come loose. I have the lengths of clutch bolts in notes. Is it a max 2 or 4?A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
I also had to buy new longer bolts to work with the thicker bands. Mine went together pretty easily though, but I read every t20 thread and watched maxrules99 video about 20 times. I still needed some guidance though.Originally posted by shultz55 View Postupon putting the t20 back together that the new heavier bands seam short in the plunger I bought longer bolts we shall see .also what a pia to remate together I might addDanW
