is it possible to install the red spring wrong ? it seems like the clutch is not opening all the way like it did with the old spring ,or is it not ssuppose to?
red spring on a t20 clutch
The red spring holds the clutch in its "closed" low range position longer, thus giving the user more low end torque before opening to its "open" higher range.
Kestian, it is amazing how much of an effect the correct throttle adjustment can make in this situation, isn't it? I was not all that impressed with the red until I got my throttle cable adjusted right, and then YIKES! GET OUT OF TOWN MAN!DESTRUCTION is just a couple of vowels down the street from DISTRACTION
before I had the throttle right I could barely turn on the concrete now it turns quick ,even burns a little rubber ,I cant wait till I get to take back out to the trails!!!Originally posted by brushcutter View PostThe red spring holds the clutch in its "closed" low range position longer, thus giving the user more low end torque before opening to its "open" higher range.
pull out the tranny , remove the clutch, I soaked mine with wd for a few days and it came right off then take apart the clutch (it all comes apart after you remove it from the shaft) watch out for the little key thing , slide out the old spring,push on it a few times and say wow thats weak compaired to the new one, put in the new one , slap it back together and walla...hope that helps
this thread is uless with out picturesOriginally posted by kestianj View Postpull out the tranny , remove the clutch, I soaked mine with wd for a few days and it came right off then take apart the clutch (it all comes apart after you remove it from the shaft) watch out for the little key thing , slide out the old spring,push on it a few times and say wow thats weak compaired to the new one, put in the new one , slap it back together and walla...hope that helps
R.I.P sage rogers 4 11 09 .
