I just aquired a Attex 450 Tomahawk with the OHV 16 hp Tec. The clutches are not sliding more than one third of the way out at full throttle in neutral. I'm going to assume something is worn out or broken in the drive clutch. What size bolt does it take to pull it?
I've never saw a drive clutch on a engine with the dome turned inward. Is this normal? Looks as if it has to be this way to line up correctly with the driven.
too high rpm one or.....it has a dead spot in it, on the shaft...
Sounds like you got the bug.
