I am looking at relocating the engine on Jennifer's Max IV and was hoping one of you clutch experts could tell me if there is an alternative to the Salsbury drive clutch on the motor that would do what I wanted. I need it to still close the same way (from the outside of the clutch inwards towards the motor) but I need either a more narrow clutch (overall) or one that allows the belt to ride on the outside of the clutch (away from the motor).
I need to move the belt as close to the tub as I can but the spring (dome) assembly on the salsbury is restricting how close I can move it. Basically the same problem as Whipper had when he relocated the engine/tranny in his Max IV springer but before I remold the lower tub I was wanting to see if there was a clutch out there that would prevent me from having to do so.
After speaking with Don I realized that I could reverse the clutch on the motor and get it to do what I want to do however I will have to also reverse the clutch on the T20 and that will not be possible without relocating sprockets, tensioners, etc. which I don't want to do.
If you know of a clutch that will work or that is just more narrow let me know.
Thanks,
Mike
Thanks,
Mike
), but I'm with Whipper on this one. It's really a piece of cake to do, and if you take your time, you can make it look just about "factory". The Comet 94c Duster for 4-strokes has a bit of a slimmer dome, but I'm a big fan of the original big clutches. Do you plan on just lowering the engine and moving the trans forward a'la Godzilla style?
