Evacuating fluid from a T-20
  • Evacuating fluid from a T-20
    For the past few years when changing the transmission fluid I've been using a cheap hand pump to pump the fluid out ( it functions like a bicycle pump ). Here's a pic of it Mity Vac Fluid Transfer Pump - Model 7240 at Sears.com
    While this solution works, it's not very elegant and the pumping mechanism is a bit rough on the palms.
    I was wondering if anyone had a better tool for the job.
    Thanks,
    chris
    thats the same pump i use its slow but it works
      I removed the drain plug and installed a valve in its place , then attached a flexible hose to it. To drain my Max II trains I simply pick up the front of the machine to nearly vertical (winch or whatever) open the valve and go do something else for awhile. The hose is routed out a drain hole and into a pan. No mess, easy as can be. The valve and hose stay in the machine, tie it off to something with a zip tie.
      I film 6x6 Trail Ride Videos. jsschwab@localnet.com
        That's kind of along the lines I was thinking, maybe use a drill powered pump similar to this one to help the process. Maybe use it on the motor also...
        Shurflo Drill Pump
          I like the idea of a hose that's routed out of the drain hole. I don't think I have anything in the garage that I could use to orientate the Buffalo vertically..
          I like the drill pump idea. Boatersworld in Lewisville has it, I may try to run out there today at lunch and pick one up...
          Thanks for the suggestion!
          chris
            The Max II I'm working on has the valve and hose on it. Easier to change the T-20 fluid than the oil and filter on the engine.
              I posted in the thread about oil evacuation! Check it out. The pump I use is super fast, verry little pumping & is self contained, no having to use a drill, or be near a power source!
              Jeff
              02 Argo Bigfoot
                Here is what I use:
                Harbor Freight Tools - Quality Tools at the Lowest Prices
