I went out riding on New Years day and once or twice I felt this wierd feeling from the Tranny. Also It wouldn't spin the right side in reverse when I got stuck (twice!) So I pulled the Motor and T20. Both bottom back 3/8 mounting bolts were broke off in the case and the adjustment appears WAY off. I don't know if it happened this weekend or if it has been that way since I got it 3weeks ago. So I spent a lot of time drilling out the bolts and trying to "easy-out" it. The "easy out" broke off... NO FUN!) So as it stands now I have a T20 sitting on the workbench that either needs bottom tapped or heli-coiled.
What do you guys think? I am thinking heli-coil because I'm afraid the boss may break and Heli-coil doesn't require such a tight interference fit.
Also to clarify the adjustment... set the space between the case and the u-channel top and bottom on each side to the same measurment, then look for 5/16ths of movement of each of 4 plungers... right? The more I read the less confident I get.
Thanks in advance!
