I'm reassembling a T-20 with many new parts. The issue I'm having is with the left side main shaft with the sprocket on it. The new bearing is all the way in the case flush, the shaft is all the way mated flush on the bearing. The problem I'm having is there isn't enough of the snap ring groove exposed on the inside of the case to allow the snap ring to clip into place.
The only thing I can think of is when RI had this bearing ground down that it ended up a .1 too thick. Any ideas or suggestions?
Mike
Mike
