What's so special about the MAX T20 steering transmission? MAX FAQ #2
  • #31
    Hey thanks for the comment on the plugs,I had the rubber boat type in they popped out then I drilled and tapped 1/2" npt and put a pipe plug in.That came out to one day.I have a bilge pump I just have not installed it.Do you think my scrambler will float with the heavier 16hp briggs flat twin?It is very rear heavy and sometimes I think the back will just sink.I am going to check out your pics,I tried to fix the attex and I had no luck at all using acetone andm trying to weld the body with a large soldering iron.I am going to try the goop on the amphicat and hope for better results,If i am correct I was told to abs black pipe and acetone.
    • #32
      amphibious drew you did an awesome job.My attex is in the same shape but the amphicat is no where near that bad.You have an awesome work area!-You could build a tank with all the room and equipment and materials you have.You did a very professional job!-I dont feel so bad after seeing all the balloon tires in your yard.I have a ton but they are all ripped up.Why I keep them I dont know?
      • #33
        Thanks for the compliments Flippy. That nice shop there are a few shots of is my uncles machine shop. Its over an hour away, but he was cool enough to order my 4140 for me and let me cut and drill my axles. Most of the work has been done in my driveway and front porch. My garage as you can see is stuffed with different toys, equipment, and projects.
        • #34
          This is what you do with the junk balloon tires.
          • #35
            Hey Larry, I tried that with the tires!
            The wife made me take them off the refrigerator!
            Ok just kidding....
            You know I am REALLY surprised, about the response I got to this thread!
            The trouble with retirement is.... I never get a day off !!!!
            • #36
              Now that's a great idea, Larry!
              • #37
                Ok just kidding....
                lol, good one.
                Thanks, check out the video. I made one a while back of it and I just edited it, threw in some pictures and text and made another thread on it.
