i'm looking at a max iv and can you put new plunger o rings in a t20 without tearing down or is a tearing down the only way?
t20 o rings
The only way I know of is to tear it down, if the plungers come out far enough to allow you to put o-rings on then you need new band liners because the lining is gone. Or the anchor pins are not in their correct place. Either way, you will need a tear down. Be sure to read the "how to" article on t-20's, and mark your bands for position if you completely remove them, because they have to go back in their correct place.DESTRUCTION is just a couple of vowels down the street from DISTRACTION
Originally posted by brushcutter View PostThe only way I know of is to tear it down, if the plungers come out far enough to allow you to put o-rings on then you need new band liners because the lining is gone. Or the anchor pins are not in their correct place. Either way, you will need a tear down. Be sure to read the "how to" article on t-20's, and mark your bands for position if you completely remove them, because they have to go back in their correct place.HUSTLEMANIAC and a HONORARY MEMBER of the
BIGFOOT ALUMNI
Originally posted by fmints View PostAlso, ensure that you put some vaseline or another type to thick lube when putting the plungers in, to make sure that you don't shear any of the rubber of when re-installing them. Plus, the plunger should come all the way out of the plunger hole with the band attached, and then slide the new rubber seals on with the lube, and slowly push or tap them back in there respected positions. I learned the hard way before reading the "how to" article on T-20's.definitely!!! Didn't think to add that, it's aggravating to cut even one when you have just enough to do the job! Good catch!
Originally posted by brushcutter View Postfmintsdefinitely!!! Didn't think to add that, it's aggravating to cut even one when you have just enough to do the job! Good catch!
BIGFOOT ALUMNI
