Accessories
Accessories are always an added benefit when you go to buy a used AATV. Winches, windshields, tops, plows, etc. can add to the value and attractiveness of an ATV but be sure to ask yourself how useful they really are to you. If you don't think you would really ever use a plow then it is probably more economical for you to look for an ATV without one. Aside from seeing that the accessories accompany the ATV, make sure that they actually work. Play with the winch and put it under a load, fold the windshield down, turn on the bilge pump, put the top up and inspect it for tears, test the headlights and taillights, watch the hour meter to make sure it is working, inspect the ammeter for movement, test the 12V power outlet, etc.
Tracks
Tracks are a great accessory that can increase the capabilities of your ATV but tracks also can add a lot to the price of a used six or eight wheeler. Again, as an accessory be sure that you really need tracks before you purchase a used ATV with them. If you are considering an ATV with tracks be sure that they are on the machine when you go to test it. Check the tracks carefully for cracks and wear. Look at the pins and ensure that they are all there and that they are in decent shape.
Ask the owner if they came with the ATV new or were added at a later date. Are they stock tracks or aftermarket. Are they rubber or plastic. Does the owner leave them on the ATV year round or are they removed after the winter months
Get Ready to Ride!
Hopefully this guide was useful to you and at least gave you some points to think about when you go to purchase your ATV. Ultimately regardless of how closely you inspect the ATV just be aware that there can always be hidden problems but the more detailed you are in your pre-purchase inspection the better off you are. Purchase the best and newest 6x6 or 8x8 that you can comfortably afford and get ready to ride. Welcome to the 6x6 World!
Pictures
scott8x8 06-03-2024, 08:05 PM
