Was out yesterday with the grandkids and the wife found a deep snow drift and low and behold got stuck up on it (took tracks off -stupid move) - what I saw was that the right wheels where spinning but the left side where not - until she put the right brake on - then the left started to spin - when she let off the right brake - left side stopped spinning again - I was under the assumption that all wheels are to turn when brakes are off. ->> Question - is this normal for these machines or do I have a problem?
True all wheel drive?
The T-20 gives you true all wheel drive, and like it was said, the Argo transmission is a differential, so only only one set of wheels will spin at a time. This is also why the engine struggles under slow speed turning with an Argo.......the differential robs a good bit of power. If you jerk the left and right sticks back and forth real fast on an Argo at high RPMs it'll generate a lot of shock load on the drive line."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Take a look at the videos in this thread, it may help you understand. Two camera angles, same Argo w/ wheel spin. http://www.6x6world.com/forums/trans...vs-t-20-a.html
The good news is, with some practice you CAN learn to feather the brakes just right....and keep up with the t-20 based machines.
Originally posted by thebuggyman1 View PostTake a look at the videos in this thread, it may help you understand. Two camera angles, same Argo w/ wheel spin. http://www.6x6world.com/forums/trans...vs-t-20-a.html
Good point Jim, a little time behind the sticks will get an average person enough skill to keep up with a t20, not to mention having a high and low range.
It works on a differential as well, but I think they say it's a "triple differential". I drove an Argo with the Admiral transmission and I'll certainly pass on that and stick with a T-20 machine all day, but to each their own. It's whatever you like best.Originally posted by Rusty-Gunn View PostIs the Admiral trans any better?"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Notes on Tracked Vehilcle Steering
T20 is clutch-brake steering
non-admiral Argo is braked-differential steering
Admiral is triple differential steering
Only the Admiral is positively true all wheel drive no matter what.
Originally posted by rodp View PostSo Gents, excuse my ignorance in these matters but can the T20 be fitted to an Ago? If so would it be worth the hassle and what would the costs be?
Thanks
Is it worth the hassle? Ask Mike when he's done.....nobody else knows yet.
