Originally posted by thorn
View Post
Conquest in the snow?
you can try member "obsessed" or "planetaux" (not sure on correct spelling)...try giving them a PM and see what each can do for you. or can place add in wanted section on this forum or other classified sections on the net.Even if you’re on the right track, you’ll get run over if you just sit there.
—Will Rogers
The Adair classic is what I was think of. Have you run them before? How much of a difference would the be in snow and muck? Do you know if they swim at all? Sorry for all the questions. And thanks for the suggestions.Originally posted by thorn View PostAdair 17" classic tracks are 1800 or Argo 13" standard tracks are 1600. I would opt for the Adair as They would handle year around conditions better and would turn your Conquest into a tank!
I have not run them, but I have ran both the Argo standard and Supertracks. The Argo tracks do well in snow and are okay in muck, but they will wear quickly in terrain other than snow. The Argo tracks as they come use a "negitive" traction aid. Meaning that the mud/snow is pushed up into the track pattern, where the Adair have aggressive grousers (positive) stciking out from the belting that paddle you through the goo/snow.Originally posted by Twizted1 View PostThe Adair classic is what I was think of. Have you run them before? How much of a difference would the be in snow and muck? Do you know if they swim at all? Sorry for all the questions. And thanks for the suggestions.
My Supertracks have 6" angle iron cleats to help paddle in the snow and do quiet well. They would not be good in harder terrain though.
What about tire chains? I figured in up to 10" of snow it should help right?Alaska floating atvs group on face book. Fixing help and trail rides!!!!!
ATV = Alaska Terain Vehicle
Tire chains won't give you much floatation in snow. Once the snow gets deep enough that the tub holds your tires up you'll be stuck.
Keith.sigpic
I was hoping the chains would help in snow covered tussocks (bunch of hip deep hills). I anti spate less than 10" of snow..... More like 4-6. I was hopping that it would assist in driving over trees that are layed down too. Thanks for the input guys! I have v-bar chains for the front four tires and last two (it is an 8 wheeler)Alaska floating atvs group on face book. Fixing help and trail rides!!!!!
