Hey guys just got my tsubaki chain from my local hardware store and I bought 2 10 ft boxes of 50-2 roller chain! I pretty sure there is 48 links in each 5 ft rear Argo chain so how do I split my chain. I was never really good at taking links out of chains so help will be very helpful!!
Got new chain
The best way is to use the tool that is designed for that purpose. It's called a chain breaker and, as tools go, is pretty inexpensive.
If you have a motorcycle shop nearby, they will have one and I bet if you have the links marked that you need broken they would help you out.
Practice with the old chain that you will throw away anyway until you get the hang of it.
You need a Heavy Duty chain breaker from Harbor Freight. Then using a wrench you count the links and mark the link that needs removed. The tool presses the pin out, a punch will destroy the chain. I used a zip tie inserted (not zipped) on every 10th link to make my count.
Curtis fold the chain in half and there should be one plate between them ( holding the 2 halves together), that is the one to do. Using a grinder to remove the exposed portion of the pins and then knocking the pins through is a fairly easy way to do it.
BE SURE YOU ARE IN THE MIDDLE and the chain is even or you've just made one chain too long and one chain too short. Use the supplied master links in the box and keep any extras under the seat.sigpic
hey curtis, being that i have exposed chains on my max 2 modification... i have tried lot's of chain lubes. really good one i just found at lowes. it's called '' super slick''. it is anti friction anti corrosion anti rust anti wear. says it drives out moisture, doesn't attract dirt, doesn't sling off. never gums up or builds up. there you go. so far i am very impressed with it. hope that helps. johnboy va.
