I sure will Vance I will have the extra links and what not!
Got new chain
Hey guys just back from the shed. Took the chain out of the box sized it up. Found the half way point (5ft or 48 links) the chain looks nice and can't wait to put it on! Just got to grind the link flat and take the pins out! Just my luck ,turned the grinder on the the motor started smoking and wouldn't move, anyways will try to find another lol!
Curtis...Originally posted by curtisbyrne View PostWhat should I use to lube the chains. I done want grease this time very messy. What can I do to keep everything clean?
I'm a newbie with the Argo so I contacted a high volume dealer that has a lot of experience with Argos and he suggested the Macs Chain and Cable lube from NAPA. I have used it and I think I will stick with it. It foams like shaving cream when applied and sort of melts into the links and saturates the chain. Some of it will drip into your pans but debris slings off and does not stick to the chain. It's easy to wipe out with shop towels if you want also.
Multi-Purpose Lubricant MAC 1370 | NAPA Auto Parts
Originally posted by Vance in AK View PostCurtis, when you break a chain in the field & have to repair it you will REALLY wish you had a chain breaker & not a hammer & punch (not that they can't work). Always keep a short length of extra chain, a chain breaker, & spare master links with you in the field.Originally posted by curtisbyrne View PostI sure will Vance I will have the extra links and what not!Chain breaker. Not expensive. What Vance said.Originally posted by curtisbyrne View PostYeah guys I can't get the pins out I got it grinder smooth but they won't budge?
Down size on chain?
Honest to god that double 50 stuff is way to expensive and I do t use my Argo under a lot of stress so would single 60 be good for the back when my new double 50 wears out? They use it on the new machines so why not. Once again I don't use my Argo under stress. Don't have tracks only ride in summer that's it.so!
I think you should maintain your machine factory specs and utilize the double 50 as equipped. Switching over sprockets is not a pleasurable experience, besides that when you sell the machine most folks on this forum at least, will pickup on the modification.
The time to buy chain is when you don't need it.
You could take the money you save by downgrading the double 50 chain to a single 60 and buy a good sturdy pair of boots and some walking poles for when your machine leaves you stranded and you get to appreciate nature more on your walk home or to camp...Originally posted by curtisbyrne View PostHonest to god that double 50 stuff is way to expensive and I do t use my Argo under a lot of stress so would single 60 be good for the back when my new double 50 wears out? They use it on the new machines so why not. Once again I don't use my Argo under stress. Don't have tracks only ride in summer that's it.so!
There's a reason why ODG uses double 50 chains in some places and not single 60 all over...
