a 20 amp switch will work fine. Your local hardware or auto parts store should have a switch that will work for you. A fuse is always a good idea to protect the circuit.
lights install
stupid question but what size fuse. 15amp?
Ok here is a little LED input. First thy do not surge when turned on. Lumins is how the brightness is rated. Also thy do not produce Heat like a regular light. Also a side note. If you use LED on the same line WITH regular lights the led will NOT be as bright as thy should be do to the BIGGER amp draw of the other lights. If you run ALL led lights thy will be rite up to spec !
Run the ground wire from the LED directly to a ground. Either you can tie to another ground wire or attach to a convenient metal part of the frame. From your power source, run a wire to one prong on the switch. attach the positive wire from the LED to the other prong on the switch.
If the switch has 3 prongs, look at the box for instructions. It should tell you which two prongs will close the circuit, or you can test it with an ohm meter.
i just have one lying around... its not hooked up to anything. btw these lights are going on my 04 honda foreman. could i just wire it to the stock light switch? i just bought a toggle switch and it says 10A 125VAC
15A 12VDC
THESE #S ARE FOR EACH PRONG(ONLY 2 PRONGS).. SO AM I GOOD TO GO WITH THIS SWITCH? sorry for the cap lock i didnt realize lol.
If these are going on your Honda then I would say Yes as thy have a Fused Light circuit already built in. Also these light will Not draw anywhere near the amps the stock head light draws !
I would tie it in and do a test run then you can check to see if any wire's are getting warm ? But I would bet ya thy won't.
If you want just start the Honda and then see if the charging light comes on at idle ?
There is Nothing wrong with wanting to play it safe that's for sure !
