Still working on the retracting outboard mount.
Stowed position for land travel:
The "legs" will get two "sleeves" that they will slide into and a couple pins to lock them in place. The prop will get a "weed guard" and that will clip into a bracket on the rear rail of the carrier rack. The opening where the outboard slides down will get a simple diamond plate piece that will just drop into the hole for more carrying capacity. I will, of course, always have the option to just remove the outboard altogether and leave it at home.
Outboard lowered for water travel:
Fits nicely. There's enough clearance that the outboard can spin a full 360. That means if I want to reverse, I can just spin the outboard around to travel backwards if needed.
Lower leg and prop position:
Places the cavitation plate level with the bottom of the hull, like is should be for good cooling water flow. The prop is below the hull to give it clear water to work in.
Coming along nicely. The only thing I had to give up was a "hard mounted" outboard mount. I'll have to lift it up out of the running position by hand power alone. That's not an issue though as the little 2 HP 2 stroke is very light and easily manhandled with one arm.
