how do i go about giving my tank a good overall cleaning and draining of old gas??
cleaning tank
I have recently cleaned the tank of my MaxIV. I drained it by disconnecting the fuel line and allowing it to gravity flow into another container. Then I removed it from the machine and put some nuts and bolts, degreaser (about a quart), and a rag inside the tank. I put the cap on and capped the fuel line end, to seal the tank. I allowed the degreaser to work for about 5 minutes and then shaked it in a manner that the rag, nuts and bolts would scrub the inside of the tank. Lastly, once it looked clean enough (about a minute of shaking and stirring), I emptied the tank, rinsed with water and allowed it to drain and air dry (about 1-2 hours in the heat). And that is that. Lastly I replaced all fuel line and filters!! Hopes this can aid you brother!!Originally posted by curtisbyrne View Posthow do i go about giving my tank a good overall cleaning and draining of old gas??HUSTLEMANIAC and a HONORARY MEMBER of the
BIGFOOT ALUMNI
got the darn thing out! i was supersized not at the tank but the pickup tube, i took it apart to find it almost clogged completely. i washed out the tank few times with water will this do?? any ideas what i can do while its out?also found this weird looking bug in the pickup tube.it certainly it some kind of insect it was dead of course but had me think what kind of bug would live in such a place but at the same time it probably got in the tank somehow and got sucked up?
I do the same thing as fmints, but use acetone instead of degreaser. then water rinse, then final rinse again with acetone as it dries quickly. I do bolts/ nuts but no rag. make sure you don't grab stainless bolts so you can use a magnet on a stick to fish them back outOriginally posted by curtisbyrne View Postgot the darn thing out! i was supersized not at the tank but the pickup tube, i took it apart to find it almost clogged completely. i washed out the tank few times with water will this do?? any ideas what i can do while its out?also found this weird looking bug in the pickup tube.it certainly it some kind of insect it was dead of course but had me think what kind of bug would live in such a place but at the same time it probably got in the tank somehow and got sucked up?
I did mine recently. Nothing easy. A lot of wiggling back and forth and some prying on the seat frame. I washed it out with hot water and then poured a one gallon can of alcohol into it to remove any water residue and let it dry out in the summer sun. Putting it back in was easier than removal. I also replaced the clams securing the filler tube when reinstalling it. Good Luck.
Blow in the tank with the forward end of fuel line in a bottle until fuel appears.
Be sure the filter is pointed in correct direction.sigpic
Did you blow fuel up to yet? I have an idea whats wrong, but if you dont find it i could be wrong.sigpic
