have conquest with the 20 hp kawi and this afternoon after running it with the new governor spring(decided to buy new and not use fabed one) it seemed to bog out after a bit.. ran great for about 15 mins and then all of a sudden just bogged. if i stop and let it sit for maybe 5 seconds it will run alright again for a little then bog again.. engine does seem to be awfully hot and carb was just taken apart and cleaned up nice. couple questions.
should my temp be running up high and then quickly dropping back down, or should it stay consistent temp? is there a safety system on say a 98-99 conquest that would shut it down if overheated? could it maybe be that my float is not allowing enough fuel to keep up with the engine? you guys know a hell of alot more about these machines than i do so any help is appreciated. P.S this machine is slowly getting on my nerves!
how much movement(coolant)should you see in the rad when running?
