Originally posted by moos-a-boo
View Post
Originally posted by DerekF
View Post
So, in conclusion, I will say that I love the new bearing configurations and will be converting my daughters Conquest over at some point. It sees much less use than mine, so will probably change them out through attrition.
Originally posted by Geologic
View Post
What I would do to that Conquest
Start with the Trans, is it High, Med or Low geared? Look at the number stamped on the top of the trans, does it end with HU, MU, or GU? (High, Med, Low gearing). Not a lot you can do about it, but I would like to see GU (Low Geared). (MU is good too, but IMHO, HU is too high geared)
Feel the Clutch Faces, with those low hrs, I would expect them to be fine, but improper operation can cause premature wear of the faces. If they are smooth, or just have a bit of wear, they are fine, if you can feel ridges/bumps, keep in mind that it will not operate to its fullest capabilities. (I've seen some pretty bad ones with up to about 1/8" worn off the faces and some bad transition bumps)
I would shim the Primary spring with a spacer about 5/32" thick (Increases Engagement RPM a bit and slows down the rate of Upshift).
I would also tighten the Secondary Spring a notch or two (Increases the rate of Downshift) (Your preferance and riding conditions will dictate this)
Definatly upgrade the Bearings
24" Frontier Tires, OR, Adair Tracks depending on what you want ( I want one of each, but have not scraped together cash for the tracks yet)
Front Pushbar/Winch Guard and Rear Rack are a MUST (weld single "chain links" on rack, under the top rail, as "tiedown points").
I very much like the 27hp Kawi engine in my Conquest (Light mods required to Mounting Plate). It does NOT make the Argo much faster, but the increased HP is very nice.
BLOCK OFF the Warm Air Intake on the Air Filter Housing. It helps a little.
ALWAYS carry some Gasline Anti-freeze, and a bit of ATF with you. If you ever have to ( and you will) use old fuel, add some of each to your gas tank, it will keep your valves from sticking and causing your Pushrods to bend. It happens, they DON'T like old fuel.
Put a small tool box together, and ONLY use those tools to work on your machine (don't forget a small extension Magnet). Eventually, you will have every tool you need to do most repaires in one little box.
Spare parts, you should carry the basics with you: Bearings, seals, gaskets, master links, Brake kit, Tappet Cover Gasket, Carb Springs/bushings, hand cleaner, Plug Kit, Air Comp, Either, ect. "Murphy's Law says that if you have parts with you, you probably won't need them"
I despise the stock battery location, moved mine to the back rack.
Get into the habit of flicking your trans into reverse first, then into Low or High, this will help reduce trans grinding. Even if your trans does NOT grind going into gear right now, it will under some conditions, example: running in colder temps than normal can cause an increase in idle RPM.
If you have a windshield, put glass in it, or take it off. Don't use Lexan or Plexi, both will scratch very easy and very fast.
Lean away from "Half-links", have one just in case, but if your chains are stretched enough to cut a link out and fit a half link, the chains are in need of replacing.
Hope that's enough for now
Oh ya, welcome to the site
