Slim - is that a carbed engine? looks like the early version of the suzuki motor (999cc?).. sprint 88 and back.
99 Conquest Chevy Sprint Engine Swap
I would say to use the flywheel from a standard. You can then use the pilot hole that the transmission centres in to help hold the shaft straight. I would then have a machinist make the shaft to fit the pilot hole and make a bracket to bolt onto the flywheel and machine fit a 1 1/8 shaft the proper length to fit the clutch you are going to use. He can also machine the clutch from a 1 inch shaft to a 1 1/8 so it wil fit on the shaft bolted to the engine. The bigger shaft give considerably more strenth.
SlimSlimpickin
Stay away from the subaru Justy. It has an iron block. the swift engines are all aluminum. It is probably 30 lbs or more heavier. good idea though!Originally posted by eightwheeler View PostYes i think we need our own post sorry for hijack Slim, so i also found that the Suabaru Justy uses a 3cyl as well and is multiport injection so no need for the big MAP sensor and wire routing as well, might be even easier than the EFI sprint motor
ATV = Alaska Terain Vehicle
if somone has info about the swift to clutch adapter, can you post any information you have (how to build it, or where to buy one) over in the thread under engines please? thank you!Alaska floating atvs group on face book. Fixing help and trail rides!!!!!
Nice video, that engine sure worked out well. I had a 1986 GEO Metro, it was my 2nd new car. I got mileage in the mid 50's, had decent highway cruise capability, but it was a dog in town. I knew the first time I raised the hood that someday the engines would find their way into ATVs. I had amphibs back then as well, but they were small units and I never thought about the Suzuki going into an amphib back then. The Geo Metro was a minimalist approach to getting decent economy back then. I have a VW JETTA TDI now, a few years from now when the car is past its prime I envision that motor going in my Future Project Vehicle.
Chevy sprint engines, why not use the car transmission? Take the CV shaft and get a sprocket put on them, would need brakes put on as well, but an automatic firefly tranny might me nice, with 3 speeds you can cruise at nice low rpm on straight roads.
I realize the engine might be offset to the side but either pushing the engine over or using a jack shaft/ pillow bearing setup.
Remember, I have zero argo experience just saw one for the first time this week.
Foes anybody have access to this site, my phone can't download the pics of the automatic suzuki engine
Route 6x6 Discussion Board: Anyone had experance installing a 4 cycle engine in a ARGO
