Originally posted by 507rzr
View Post
Wild wolf 295
Did you try a little gas down the spark plug hole? If you have spark and the compression is good and you are sure the timing is correct, then I would say it's fuel. Try some fuel down the spark plug hole. Torque the plug back in and see what happens. You might get the spark plug a little too wet so if you pull it a couple of times and nothing happens, pull the plug and clean it off, then put it back in and try again."Racing is life. Anything that happens before or after is just waiting."
This is a stumper. From all the posts on this thread it seems the thing should fire up and run. Where are you located?Stuck in the seventies- not in the swamp.
I've put fuel in the plug hole and tryed either in carb and cylinder. I've worked on things like this for 35 years. Was an auto technician for 20 years. I know my way around a toolbox. Only thing unsure to me is points. I'm using a buzzer inline to check timing. Timed it 1 complete round plus .25 on dial indicator BTDC. I did replace the key switch early on. Is it possible I did something wrong there. I have spark during crank but could I be missing something there? Only other question in my mind is losing spark under compression. Spark plug always seems dry when I take it out though. Crankcase seems mostly dry
With all the either sprayed in there, I might pull the head and look at the cylinder. Then if ok I might try a little oil in the cylinder, bolt the head back on and try the gas thing again.sigpic
You are absolutely sure the starter is turning the engine the right way? Have you tried it with the recoil instead of the starter?Originally posted by 507rzr View PostAlthough I do have spark. Maybe it is a little weak. What could cause that? This thing won't backfire, pop or anything. Just spins when I turn the key. It doesn't even try to act like it's gonna run."Racing is life. Anything that happens before or after is just waiting."
Or other wiring issue. The recoil with key switch un connected would make system stand alone, though you may have to yank plug wire to shut down if it starts.sigpic
