Originally posted by riotwarrior
View Post
What should I always have with me when riding AATV's?
I've got at least a 5 gallon tank, it's not enough my machine is a pig on fuel absolute PIG with that Tecumseh HH120 12Hp engine.Originally posted by PlumCrazy View PostWe take a 5 gallon on the trailer, but a full tank in my MaxIV will last 4 days+ at Busco Beach or Pine Lake.
Now once that diesel is in it...well all bets off then LOL I'm sure it will sip fuel compared to the 12hp. That's why I am looking to find out bout these clamp on canisters. Plus good for chain saw fuel/oil
E D I T ..
Here after phoning a buddy he said these where what he was looking at for his ATV/UTV
Home of the worlds toughest overland, offroad, accessory fuel containers, water containers, and mounting hardware. Rotationally molded for unrivaled strength with multiple mounting options available. Find the perfect fuel container for any adventure.
I'm thinking 2 gallon fuel and water.Last edited by riotwarrior; 11-08-2013, 03:11 PM.MUSCATEER 6x6
MUSCA TUR BOTA then eh?
94 F350 4x4 7.3 IDI ZF 5sp
Al "Camo pants"
My MaxIV will probably drink more also, once I pull the 18hp Vanguard out this winter and put the 3cyl gas Kubota in.Originally posted by riotwarrior View PostI've got at least a 5 gallon tank, it's not enough my machine is a pig on fuel absolute PIG with that Tecumseh HH120 12Hp engine.
E D I T ..
Fuel Cans : Gas Pack : Gasoline Containers : RotopaX.com
I'm thinking 2 gallon fuel and water.The trouble with retirement is.... I never get a day off !!!!
I have to ask, if vanguard works well..seems to you did not complain, why remove and replace with a gas kubota and I never new they made those? Why not do a swift change with 3cyl engine then?Originally posted by PlumCrazy View PostMy MaxIV will probably drink more also, once I pull the 18hp Vanguard out this winter and put the 3cyl gas Kubota in.
Whats the merrits to this bota engine you speak of what size rpm hp etc???MUSCATEER 6x6
Al "Camo pants"
Gas is cheaper than Diesel and no smell.Originally posted by riotwarrior View PostI have to ask, if vanguard works well..seems to you did not complain, why remove and replace with a gas kubota and I never new they made those? Why not do a swift change with 3cyl engine then?
Kubota is 24hp, 3cylinders means TORQUE.
3600rpm is the same as the 18hp B&S, so the ground speed will stay the same.
Don't want to go Faster, we use them for trail machines, not Go Fasts.The trouble with retirement is.... I never get a day off !!!!
I got a extra pair of gloves and a chain saw. If you need all that junk onboard I'd be looking for a newer more reliable machine. Your overloaded before you get in!!sigpic
Camo side up, Rubber side down!!
2014 Argo 750HDI SE
2008 Honda Rubicon, Camo
2008 Jeep Rubicon, Black, 2 door, 6sp, 2 Warn winches.
If I am just going out for the day, I carry:
5 gallon can of gas
gloves
chainsaw
12V compressor
stop leak
100' of rope (for self-extraction)
a tree protection strap
charge adapter for my cell phone
spark plugs and wrench
drinking water (amount depends on the length of the trip)
Valve stem wrench
I have thought about adding an anchor to use as a deadman for swampy areas where there is nothing else to pull against, but that definitely takes up some space. If I am going to be out for a few days, I add camping gear. That pretty much takes up all of the free space in my Max IV with two adults riding up front. If I think I am going to be a long ways out (more than 10-15 miles), I carry a few more tools because it can become such an ordeal to get the buggy out of the woods if it breaks down out there. It is so much easier to get it out under its own power. I don't think I would carry everything listed in earlier posts, but I am considering some of the items that I hadn't thought of on my own.
