This is a single speed Borg-Warner, can't recall the model# but its a low geared unit with a gear ratio around 16.3 to 1. There are similar units made by Spicer and other companies too. Nubs has the link for a similar 2 speed unit. These are very simple and inexpensive transmissions that can take a lot of power and abuse.
The machine this transmission is in will have no chains at all. It does have a drive belt between the clutches, but has a auxillary shaft coming off the transmission that will go thru a right angle gearbox then transmit power to the front axle via a drive shaft and differential. Currently working on a suspension for the middle (unpowered) axle.
This machine will have tracks, and a powered front and rear axle.
