Amphibious walking beam trailer
  • #46
    I drill 3/4" holes and use the body plugs for max. I install from inside mainly so I don't have to get under it. What did the tub end up for weight?
    • #47
      Nice job.
      What's that beast in the background?
      • #48
        That works for me, keep it simple with the same size as the Max.
        The tub came in at 48#. The trailer as it sits, 225#, half the weight is tires and wheels at 116#.
        I'm very happy with the weight, it's half the weight of the other two I built.
        • #49
          Nice job.
          Thanks Jim.
          Thats a suzuki buggy. It's got a 3 cyl metro motor with samurai tranny, t-case and axles. Front and rear steer with a thin wall chrome moly frame 1245# wet on the scales.
          Runs on 33x9.50 tires in the summer and Camoplast tracks in the winter.
          • #50
            That is a way cool machine you have there
            ST400R ATTEX(Smiley)
            500 Super Chief
            • #51
              Yes very cool. Looks like fun.
              • #52
                Originally posted by Hideous 4x4 View Post
                Well she's just about done. I'm running out of room in the shop, I want to leave it inside for a while longer just to make sure the glue is fully cured. This is the basic trailer, I will build a cover out of the 18oz truck tarp material. What did you guys use for a drain plug?
                Tell me about that tracked buggy in the background! Is that Suzuki I see??
                • #53
                  Thanks Andyman
                  • #54
                    Thanks tbone. It's so much fun that it should be illegal!
                    • #55
                      Check post #49, thats the basic's. Here is the build thread on it Just another lightweight buggy build - Zukikrawlers
                      Used to run 31x15.5 Terra Tires in the snow and it went ok, then found the tracks on eBay. Took some fabbing to get them mounted but its a whole different machine now.
                      Never been stuck to where we had to winch. The only time its been stopped in on real steep climbs.
                      If you want anything specific I will be more than happy to reply.
                      • #56
                        I adapted a ball coupler to the coupler that is mounted to the max, just incase someone else has to pull the trailer. It slides into a slot on the tongue and pins into place.
                        • #57
                          Wow, totally missed page 5 completely lol. That's really cool and I'm surprised I haven't come by it already or at least had someone esle share it to me lol...I'm a bit of a Suzuki nut (see screen name lol), I've owned 27 Samurais over the years, a bit of a whore some say
                          I'll read over your build thread as soon as I have a few minutes to sit down.
                          • #58
                            Wow 27! I had 12 at one time but down to 1 junker, two tube buggy's and two built sami tin tops for daily drivers. I have most everything to build a rear engine independent suspension buggy. Just to many irons in the fire now.
                            • #59
                              I made the mistake of remodeling the rec room before I finished the trailer. It turned out to be a bigger job than anticipated! Then just had to make 2 elk antler end tables and a floor lamp, but it's done and the trailer is finished maybe. Trying to decide if I want to mount a gas can to it.
                              Made this cover out of the 18oz vinyl coated polyester, it has a nylon pull strap around the bottom to hold it on.
                              I didn't like how it sank in the center so I made a removable bow to keep the water running off.
                              • #60
                                I am in awe of the fabrication skills. From the hitch, to trailer to the cover!
