So this is not correct?what is the towing capacity?
Originally Posted by ToryG
Hey Mike
Just to back up my prior posting about Argo's making better tractors just check out the factory specs for towing capacity for Max and Argo. All current Max2's, Max4's, and Buffalo Trucks have an equal towing capacity of 1000 lb's. The Argo spec for the 16 HP Vangaurd is 1200lb's and the Avenger EFI 8x8 is rated at 1800lb's.
Originally posted by jerrynuss
View Post
Hey Mike
hehe. Let's put the dozen sheets of plywood that Rock Doctor had on his Conquest on the Buffalo and try a slight off camber climb. The buffalo has a way higher center of gravity even before you load it, the argo has the engine on the floor and a wider stance and wheelbase, and the cargo area starts a few inches off the floor. Low range in tough spots and heavy loads, no problem for the argo. The Buffalo would be burning up belts trying to match the hauling ability of an 8. I had a 1/2 ton of limestone rock in the back of my response, went for a swim in a farm pond. It floated, but was definitly not nose heavy that day
