6x6 is pretty much right on the money. There isn't a whole lot of weight savings by taking out the motor and gas tank. My JLO 2 stroke motor weighed around 75lbs, my 7.5 inch electric motor weighed 60lbs, plus 20lbs for the electric speed controller, so that's pretty much a wash. If your motor is larger you'll save more weight. The amount of battery weight depends on the amp hours of the batteries you use, which directly relates to run time.
What kind of performance and run time are you looking for? Basically if you want top speed then you want higher voltage but you'll have shorter run times. Decide how you intend to use the vehicle and then we can figure out what you need. I can say that my Attex with 240lbs of batteries gives me a total vehicle weight around 750lbs, and at 48 volts geared over all at 16:1 I can easily drag a 600lb log. Ideally you want to keep battery weight as low as possible to meet your needs. Gearing should be set to let the motor spin in it's most efficient range most of the time. I spend most of my time pulling load at low speed so I'm geared fairly low. The motor has full torque from 0 rpms but it's also drawing the most amps at low rpms so you want to let it spin faster to keep amps down.
Neat idea though.
