I've been reading and studying on here for quite some time and still haven't made up my mind what to do with my badly worn/bent sprockets and axles in my 980. I've tried to take info from several different post to figure out what to do but I'm still questioning many things. Here are a few ideas I'm considering but as the Hustler is the only AATV I have I don't know anything other than what I read about other manufacturer parts. I need some opinions from the pros on this sight.
Option 1: I buy 1-1/4" Argo axles and sprockets. I think I would have to have the inner end of the axle turned down to fit a stock size Hustler 1" bearing and would probably use the old style 63mm outer Max bearing. I don't even know what teeth count sprockets are available from Argo so maybe that's a problem? How do Argo sprockets attach to the axles? I like this option because I end up with all new parts that can be replaced with off the shelf stuff.
Option 2: I go all Max. I install Max 1-3/4" axles, again use the 63mm outer bearing, Max sprockets, and I don't know for sure what to do with the inner bearings. Some pics make the Max axles look like they use bushings for the inner end of the axle? Like the Argo option I like the fact that I would be using new currently manufactured parts. Would these Max axles be hollow?
Option 3: I have some 1-1/4" axles made locally and probably use my stock wheel hubs. Max outter bearings again with stock inners. I imagine I would have keyways cut into the axles as well as having some off the shelf sprockets bored and keyed to match. I expect this would be pretty easy work for a real machinist (unlike me) but would probably still run up quite a tab.
I appreciate any insight you guys might have. I've seen where some guys have done similar mods or variations of but I can't quite get a plan together.
Thanks!
Thanks!
. LOL It's just a vicious cycle...
One of my brothers told me about the taperlock flanges that they used on plywood mill machinery and that is what I am wanting to try. He said they DON"T move once locked down.
