Ill try to get pics for the body sag tomarrow
Max IV work in progress. (Coyote)
15 hours of hard labor. Cut out and moved angle for battery box to hold a bigger battery. Welded in 1/4 inch angle for transmission to bolt to frame instead of having the slotted frame. My secondary clutch arrived today, thanks fed ex. Installed red spring in secondary.
Removed those rattle trap U channels and made my own out of 1/4 inch angle.
The controls feel much better now.
Reinstalled t-20 and bracing around trans, Installed my chains. That was fun.
Opened up the front of the engine stand so I could adjust t-20. welded in angle to strengthen stand. Installed and aligned 27hp kawasaki.
Long day and I'm tired.
Thank you all for the compliments. I have been reading every forum I can learning these machines and there queerks. Trying to modify as much as possible to make it better. Wether it is right or wrong. I hope to be riding with everyone soon.
He did check out the pics of the t-20 mounted. Individual linkages coming off the diamond shifters running down down the chain channelsOriginally posted by mudbug3 View PostCoyote
The next modification you should think about doing is the split shifter modification. No more rocking the tub back and forth trying to get each side of the T -20transmission gears lined up.1995 Max IV
, (#11582), 23 HP Vanguard, Custom aluminum bellyband/roll-bars with direct winch attachment. Recreatives track kit.
Work in progress. Front windshield and canvas enclosure for winter use.
Alaska AATV Owners Group https://www.facebook.com/groups/alaska.AATVs/
The mod I'm working on now is my back seat. I was working on the flip up seat today working a few bugs out <thanks Buggyman1>. Wanted to have a little bit of storage. Also working on mounting my 4 gal flat gas can for when I go in the mountains. After that I will be mounting an alternator. I tend to run alot of lights.
Well, dang on Coyote!!! That is one sweet looking IV!!! You've made some major modifications and that engine from Daniel is soooo stellar!!! You are coming to Busco, right?? I hope to see you there. Great work!!!HUSTLEMANIAC and a HONORARY MEMBER of the
BIGFOOT ALUMNI
