Wow parts sticker shock $$$
  • #16
    why do you think the axle needs replaced?
    1996 MAX IV ,KUBOTA DIESEL
    MAX II 30HP Bandolero
    • #17
      Originally posted by old silverback View Post
      spot welding is the only way the sprockets will not move EVER. Steve
      YES, even when you need to get it back apart.
      Originally posted by snake stomper View Post
      Guys I only welded it because I knew the axle was going to Need replaced along with sprockt when I cut and remove this winter was putting new bearings in it. Thx
      An enlarged hole does not mean an axle is junk. The hole can be drilled in another location. Read this post on Body Bound Bolts http://www.6x6world.com/forums/attex....html#post1079
      • #18
        Thax I will read the artical and look at other solutions. Thank for all the advice. I do try to search for some answers. But with out posting on this forum There's not much resource out there
        • #19
          We are here to help. Most active members post frequently, and to maintain correct information given out, we will and should correct improper service techniques and in accurate information. No one should take it personally unless they are personally ridiculed.
