I have torn down my 1995 Max4 to the hull. looks like i have solid axles, but all the sprockets and tensioner sprockets are ate smooth up. Some of the bearings feel rough. Im going to replace everything.. chains, sprockets, bearings. I was wondering if anyone has found other sources for bearings/sprockets. I have found the chain locally and the same shop is looking for the bearings. Any suggestions?
Btw are the sprockets on the T-20 easily replaceable? As in from the outside of the unit, not pulling any output shafts?
and.. the inner bearing flanges that bolt to the frame have no zerk fittings. Can you get some with that fitting on there?
