Had some success this weekend and it moved under it's own power but I think the easy honeymoon is over as it doesn't have reverse on the left side and the driven clutch I think needs to come apart.
It definitely takes some getting used to balancing the throttle and control sticks to keep from either revving it to the moon or stalling it, but I think that will come with time. It moves forward well enough but I only have reverse on the right side, which is a bummer.
I checked the linkage adjustments, and both top and bottom on both sides are right at 11/16" from the case, and the plungers on all 4 pull out to just flush with the case when pulled to their maximums. I tried tightening up the lower left plunger a couple threads to see if reverse would grab, but didn't get anything out of it. I tried to remove the diamond shifter, but it has a nice clip in groove lock and my clip pliers are away in storage. I don't suspect anything with the pin since I have forward, but also don't know quite enough to say for sure. My current guess is the anchor pin for the band has come loose. I'm going to start a thread in the Transmission section for more troubleshooting exposure.
Then the driven clutch. It seems either the spring isn't locked into the place it should be or it broke, though I did not find a broken edge. Thoughts? I'm probably pulling the T-20 anyways and will be removing this anyways, so but am I looking at simply assembling it correctly? Getting a new spring? Or needing a new driven clutch assembly? Here are a few pictures.
The spring actually got caught on one of the teeth.
