What would cause the T20 to have a high pitch whine when traveling forward ? Everything works good but has the whine noise .
T20
I got the tranny out and torn apart every thing looks good the band measured the same as the new ones but two of them had small pieces missing the out put shafts show some wear on the splines(not sure what is normal) the machine had 92 hours on it when I bought it and i don't think the fluid was changed, the drums looked good all the bearings look and feel good,am I missing anything?
look at the pins on the diamond shifters and make sure they aren't worn. Also look at the planetary gear components and make sure they all look good. Make sure all bearings rotate smoothly and are tight. If none of these indicate a problem I don't know what could cause the whine. Are you sure the whine was coming from the transmission?
